Seeking point density for on-machine inspection
I am seeking standards or specs that will answer the question, "How many points are required to be able to inspect and specify a surface?" I am interested in on-machine inspection, although info relating to coordinate measuring machines (CMMs) might provide a hint. I have access to ASME Y14.5 (Dimensioning and Tolerancing) but that does not specifically address this issue (or I haven't found it, if it does). Ultimately, I want to obtain an accurate assessment of surface profile variations.
Thank you.
Dale C.
Library manager
Thank you.
Dale C.
Library manager
RE: Seeking point density for on-machine inspection
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
