NH3 Bulk Modulus????
Does anybody know where I can find the bulk modulus for liquid ammonia.  Thank you.
RE: NH3 Bulk Modulus????
Erik,
Based on a celerity or speed of sound of 1729m/s in ammonia at -33 deg C and a liquid density of 680kg/m3 I back calculated the approximate bulk modulus K as 2.03 GPa.(approx 294,000PSI)
   C = Sqrt(K/density)  for a rigid pipe
I hope this helps
Mech85,
Thanks, the speep fo sound in ammonia is what i was looking for. Where did you find that value? Im new to the field and suck at looking things up.
