SSI Encoder Wiring
SSI Encoder Wiring
SSI Encoder Wiring
Has anybody ever seen an SSI encoder interface that only uses 2 wires.  I beleive the standard is 4 wire, 2-clock and 2-data.  I am trying to retro fit a servo drive.  The drive was custom made to change the buffered encoder out port to an SSI port.  This SSI port is connected to a PC controller and is used to close the position loop.  I'm just confused as to why only 2 wires.  This doesn't seem to comply with any standard that I am aware of.
