UKRAINE STEEL
3
UKRAINE STEEL
UKRAINE STEEL
I am having some nozzles added to a vessel. As a part of the specification for the alteration, it states that materials from Eastern Europe or Russia need to be approved on an individual basis.
The vessel fabricator has manufactured some of the nozzles using SA106 GrB material from a Ukrainian company called JSC. Does anyone know specifically of any quality problems with this company? Does anyone know where this kind of information can be researched?
RE: UKRAINE STEEL
Have you conducted a shop audit of JSC to determine if they can supply steel to an ASTM/ASME certification?
RE: UKRAINE STEEL
I second metengr's comments. Typically approval of a manufacturer might start by looking at their certifications and QA/QC procedures then perhaps a review of some typical documentation that they might provide to see the quality and characteristics of the materials followed by a shop audit of their facilities, and perhaps lastly some independent testing of random samples of their product.
That said, how far down this path you go can vary widely depending on the end user requirements, the value of materials to be purchased, and the level of risk.
RE: UKRAINE STEEL
we deal with AMLs every day.
the problem is, was the manufacturer made aware of the material restrictions at time of quoting or at time of purchase order.
If he was, make him replace it.  or pull samples from the heats and retest chemicals and physicals to see if they match MTRs and meet code.  THEN you can go to the user and ask permission to use.
Its embarrassing to ask to use only to find out later it's sub-standard
RE: UKRAINE STEEL
Thank you for your replies.
The manufacturer was aware of the material restrictions at the time of quoting and the end user has asked that the material be replaced. So that is how we are proceeding.
RE: UKRAINE STEEL
Sounds like you need to be able to audit and justify (every pour, alloy, and heat!) of every pound of the steel that was used.
Or replace it.
