Driven Piles directly exposed to Seawater
I am involved in a job located in Florida where we need to install a single pile structure in a Canal to support channel monitoring equipment. What is the typical type and grade of steel that is used for piles in direct contact with seawater? We have thought about using 18" to 24" diameter stainless steel pipe for corrosion purposes. Is stainless steel an acceptable material for a driven pile? Also, if you were not to use stainless steel, what type of coating would be recommended to help prevent saltwater corrosion? Any advice would be greatly appreciated.
RE: Driven Piles directly exposed to Seawater
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
www.VacuumTubeEra.net
No we have not considered that yet.
Thanks for the info. I have already been in contact with PDCA and they were very helpful.
