config.pro help please
Hi folks
I'm a complete newbie at ProE, so apologies for any stupid questions in advance.
I have Wildfire 3 and I seem to have managed to install it without setting up any config files. I've done some reading on it, and I think I could really do with these, especially for search paths and standard settings.
Could anyone explain to me how I go about creating these from scratch,as I don't appear to have any set up. When I look in Tools>Options, there is nothing there.
Just to help explain my current setup, ProE is loading from C:\Program Files\proeWildfire 3.0 and I generally will be accessing a network drive to store part files etc. in case that's of any use.
Thanks folks
Thanks folks
RE: config.pro help please
All the config.pro files are simple ascii text files. You can create them and edit them with any text editor. You can make them through the Tools/Options interface if you want but it's a little slow & cumbersome. One good thing is it avoids misspelling options & has a search interface.
If you start the help system, go to the fundamentals section and search for config you will find all kinds of info. Here is the fundamental part about how Pro/E reads config files at startup:
Pro/ENGINEER reads configuration files automatically from several areas. If a particular option is present in more than one configuration file, Pro/ENGINEER applies the most recently loaded/read setting.
At startup, Pro/ENGINEER first reads in a protected system configuration file called config.sup. It then searches for and reads in configuration files (config.pro, config.win, menu_def.pro) from the following directories in the following order:
loadpoint/text (loadpoint is the Pro/ENGINEER installation directory) - Your system administrator may have put configuration files in this location to support company standards for windows configuration settings, formats and libraries. Any user starting Pro/ENGINEER from this loadpoint uses the values in this file.
Login directory - This is the home directory for your login ID. Placing your configuration files here lets you start Pro/ENGINEER from any directory without having a copy of the files in each directory.
Startup directory - This is your current or working directory when you start Pro/ENGINEER.
Note: The local configuration files (config.pro, config.win, and menu_def.pro) in your startup directory are the last to be read; therefore, they override any conflicting configuration file option entries. The config.pro file does not, however, override any config.sup entries.
You can create and store custom configuration files in your current working directory. These custom configuration files usually apply to specific projects.
I did trawl through the help files and found too much info, such that I'm non the wiser. It seems they can be placed in various locations, I need a config.sup and possibly a config.win. It tells me a config.pro can be in my loading directory, where ProE lives, and also in various working directories, which one it uses depnds on latest date etc. It all seems very complicated and I have yet to find where it shows me HOW to make one and what, exactly, to put in it. Is there no simple way of doing it?
Config.win is your window postion settings. I have never used one. (Ducks from all the people who will tell me how beneficial they CAN be.)
The variuous directories that contain the different config.pro files help control things like compnay, project and user settings. They load in that order with the lates setting being the final one that is set when you use Wildfire.
Your best bet is to get an example file and look at the options that have been set. I have one on a CD I can email you tonight. I'm not using Pro/E at this job.
If you want it, email me at: looslib-tx <at> earthlink.net
Ben Loosli
Search.pro contains the paths to the folders you want to search for assembly components in the order you want them searched.
Ben Loosli
That sounds fairly simple, but do I need this config.sup? If so, what goes in there and where should that live and where should I locate my shiny new .pro file I will create?
Thanks for the advice.
PS I PM'd you my address in case you get chance to send a sample.
Ben Loosli
Right, again apologies for being think, but just for clarification for a dummy (Me)
Load point - Does that mean where WF3 resides on my HDD, in my case C:\Program Files\proeWildfire 3.0\text, I think that's correct, but just checking
Next question(s), I can have more than one config.pro. Where do the others live and how many should there be and why so many? Why not just have one in the loadpoint to set all my requirements?
Cheers
John
I also ran my work colleagues config.pro file at http://ww
It came up with a whole heap of errors, whereas Ben's came out clean as a whistle.
I'm not sure I'm capable of editing the sample I have to suit our set up at work (Filepaths, units options etc), is there just some basic info I can start with to get me going, or can I cherry pick certian features from the example I have and delete all that is beyond me without impairing ProE functionality?
You can take a larger, complex config.pro file & dumb it down by putting an exclamation point (!) at the start of each line you want to deactivate. The leading exclamation point turns that line into a comment line & Pro/E ignores it.
While the config option system is complex, it is versatile and allows CAD admins to enforce standards, something that is sadly lacking in many other CAD systems.
Google search config.pro and you'll find some free basic config files out there people have posted.
I've got a couple of my own, but generally modify the companies to suit my style and habits.
David
I think I can count this one as resolved.
