Text to formulas
Text to formulas
Here's a "cheater method" that might help some of you from time to time:
Suppose you have a spreadsheet with a whole bunch of data in columns, and you want to list specific outputs from a column in a row (like with paste special | transpose), and you want the output row to remain linked to the column data (unlike paste special | transpose).
You could use the index() function to select the desired data...
or you could cheat as follows - make your row with a couple example cells containing the desired formulas, except use ' to mark the formulas as text. Drag across the desired range to generate a row with text that displays the equations you'd like to have. Copy that row and paste into notepad, then copy from notepad and paste back into excel - presto! you now have "live" formulas instead of text.
ex:
'=A1 '=A3 '=A5 '=A7 '=A9 '=A11
copy into notepad and get
=A1 =A3 =A5 =A7 =A9 =A11
copy into excel and they're live...
ex:
RE: Text to formulas
Cheers
Greg Locock
