HELP NEEDED WITH SOLID WORKS MACROS USING VBA
Hello Guys! I am a programmer starting with SW;
I've never programmed in VB, I came from JAVA world,
Where it's easy to fins docmentation about the APIs (and
all the Methods, Objects and Properties available...
see for instance:
http://java.sun.com/j2se/1.5.0/docs/api/
But I miss this in the SW World!
Is there any online API brower where I could see all the methods and Objects?
Even my VB Editor don't assist me with all the methods and properties availables.
Thanks in advance!
see for instance:
Thanks in advance!
RE: HELP NEEDED WITH SOLID WORKS MACROS USING VBA
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MathCAD 14.0
Sounds like your problem is more to do with knowledge of VBA. Start simple. Lots of help available with MS Office (especially Excel). A few lessons there, and you will be ready for SW API.
SW API can be a bit tedious, because it uses methods for things that ought to be properties. I usually end up writing lots of helper functions to ease that pain.
If you are new to VBA, learn about early binding. That will help you take advantage of the VBA editors "intellisense", which will present an object's properties and methods.
http://
http://www.EsoxRepublic.com-SolidWorks API VB programming help
A star for you.
Standing
SolidWorks Pro 2009 x64, SP3.0, PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB, nVidia Quadro FX 4600
