Welding Reference?
Welding Reference?
I am a chemical engineer who obtained a job out of college in the utility industry. I work at a power plant with 6 large heat-recovery steam generators (HRSG, aka boilers on the back end of combustion turbines). I am a maintenance planner here.
Frequently I need to create work packages and obtain materials for jobs which require welding, whether it is routine maintenance/construction or if we have a boiler tube failure and need to replace it.
I'm getting tired of not understanding the jargon the workers themselves or the people who have been at this for 30 years throw around procedures and materials they're going to use for P91, P22, 8018 B2 rod, 7018, 6010 rod, etc.
Is there a reference or set of references I can get that can describe the various metals and rods used to join those metals? As an example tonight I am supervising a job and they need 6010 welding rod. How could I have known that ahead of time? In this case Google is actually very deficient for me thus far, it seems like technical trades didn't really make it to the internet.
Thank you
M9D
Thank you
M9D
RE: Welding Reference?
If you do not have time for that, then Lincoln has many excellent books on welding from their institute.
https://ssl.lincolnelectric.com/foundation/
B.E.
http://ww
http://w
hope this help u
S
Corrosion Prevention & Corrosion Control
For basics, the electrode (rod) designation provides a lot of information. The "6010" reference you made, for instance. The first two numbers (60) refer to the tensile strength in ksi of the electrode material. The next number (1) tells you the position this electrode is best suited for. In this case, the "1" indicates all positions (flat, horizontal, vertical and overhead). If that number were a "2", the electrode would be better suited for flat or horizontal positions only. The last number has to do with properties of the flux coating and what that can impart to the weld metal, including its alloying properties, its depth of penetration, its protection of the weld metal during cooling, its tenacity as a slag, etc. An electrode manufacturer will have the properties of each in their literature and they are generally the same from each manufacturer.
http://www.nationalboard.org/default.aspx
http://c
Either of those short course should have you up and running in a few days.
Best regards - Al
