Equipment Schedule vs Equipment Specs?
For an Engineering Project, what is the purpose of Equipment Schedules?
I understand that the specs are a detailed description and listing of equipment characteristics, performance, materials, etc. that the installer will bid on.
So what is the Equipment Schedule used for?
Are Equipment Schedule and Equipment Specs the same thing?  If not, what is the difference?
RE: Equipment Schedule vs Equipment Specs?
I guess it is possible the Equipment schedule is a confirmation list of equipment with quantities.
Equipment Spec would then have each item on the schedule with a specification of its properties and performance.
Is this for tender or for construction?
Hi engineerheriam
I suppose they could mean the same thing however the equipment schedule could be when the pieces of equipment are due for delivery either to site or your works.
desertfox
Or it could be a schedule of when the equipment is needed. You probably would not need all equipment on site at the start of construction.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
An equipment schedule is a listing of the equipment required with quantities, it generally gives some high level of information about the equipment.  The you go to the data sheet or specification to get the details.  It's like a line list, only for equipment.
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
