Heat Exchanger Channel with a Body Flange
I am attempting to build the following rear (bottom)channel assembly in Compress:
Tubesheet (integral with shell and channel)
24-inch long channel
Body Flange
36-inch long channel
Ellipsoidal head with 1" SF
Any suggestions on how to build this in the Compress Heat Exchanger module?
Body Flange
RE: Heat Exchanger Channel with a Body Flange
To build any part of an exchanger in Compress, the only way I know how to do it right is to build the whole exchanger.
Fitter, happier, more productive
As stated previously, the bottom tubesheet is integral with the shell and a cylinder on the tubeside. The cylinder on the tubeside (24-inches long) is attached to a body flange. The mating body flange is then attached to 36-inch long cylinder with an ellipsoidal head closure.
I have attempted to build the entire exchanger in the Compress heat exchanger module. The issue I am having is bottom tubeside assembly that is described in the second paragraph. From what I have tried, Compress does not seem to like this configuration (cylinder/body flange/cylinder/head). Perhaps Tom or others may have some ideas.
