Pro_E Chamfer Dimension
New User in Pro_E.
How do I dimension a chamfer? I would like the dimension to have a leader line and show as ( .06±.01 x 45 deg ). I always get a callout like .06 measuring the length of the chamfer?
In the properties menu, under the display tab the chamfer style box is greyed out? I looked under help and cannot find any information on this.
Thanks in advance.
Thanks in advance.
RE: Pro_E Chamfer Dimension
I did find out that you have to create the chamfer a certain way in order for the drawing to show correctly.
If you create the chamfer as 45 X D you can then show the dimension as.
Example: .06 X 45°
Please note, if you use the 45 x D chamfer option you cannot come back later and change the angle. It will always be 45.
Fighter Pilot
Manufacturing Engineer
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
