pre-engineered metal building purlins
I am structurally evaluating the roof framing of a pre-engineered metal building to verify its ability to support the additional weight of a new roof added on top of the existing roof. I have checked the light gauge steel roof purlins for flexure, shear, and deflection. Can anyone tell me where I can find equations, etc. for checking web crippling of the purlins? Thanks.
RE: pre-engineered metal building purlins
Mike McCann
MMC Engineering
BTW - many (most) of these metals buildings are well engineered - to the point there is not an extra ounce of steel in them. Retro-fitting or adding loads can sometimes (almost always) be a real problem.
Good luck...
AISI Link
The Client is installing the new roof over the existing using the roof hugger system. They have done so on other pre-engineered buildings with which I was not involved.
The added dead load is approximately 2 psf. The main frames and foundations can handle the additional load. Calculations indicate the purlins are adequate in flexure, shear, and deflection, albeit some require composite action with the roof hugger system to be adequate.
I am concerned that web crippling could be a problem. I will go to the ANSI site and see what I can find.
