Permanent Sediment Control for a Huge Dirt Lot
I have a project with a 15-acre dirt lot in an industrial area. There will be a direct discharge (e.g., catch basin) at the lowest point but the sediment control is a big concern for this big dirt lot (The site is flat though).
I think that a simple filter in the catch basin can't resolve this sediment issue.
What would be a good permanent sediment control measure for this case? A nice vegetated swale measure is not feasible at this point.
Thanks in advance for your expertise. :)
RE: Permanent Sediment Control for a Huge Dirt Lot
How much rain do you expect in your area? What part of the country?
For the whole 15 acres you only have one inlet? msucug I think is on the right track with check dams and hay bales with silt fence.
Another good way is to build a small detention pond at your low point. Slowing water velocity to zero for a bit will allow any suspended solids to settle out. You can achieve this by building a specialized inlet to your storm system.
What I mean is for your inlet 'box' if you will, constrain the amount of flow that can get in for you typical storm. Water will pool but eventually get out. On this same box, have an emergency overflow for a very large storm to drain, so you don't create a massive lake if you will.
http://www.soiltac.com/
