Bending Capacity of Micropile Splice
We are being asked to design micropiles to IBC 2006 code.
IBC 2006 Sect. 1808.2.7 requires that pile splices develop 50% of the pile capacity in bending.
We'd like to drill the low headroom micropiles utilizing male to female threaded casing. Does anyone know of a resource or method of calculation to determine the bending capacity of a threaded casing splice?
RE: Bending Capacity of Micropile Splice
I've seen designs for soldier beams using threaded micropile pipe where the bending capacity was reduced anywhere from 35% to 65%, but I've never seen any data to back up those assumptions.
One would think that others have tested the bending capcity of threaded casing and it might be possible to interpolate the data to the various casing sizes, so long as the material properties are known.
The micropiles will be loaded in compression. The only bending would be a result of accidental eccentricity. I am told that the "building official" will not allow an exception to the above mentioned code requirement.
For this particular project, even though the magnitude of any potential bending may be negligible, we are required to provide a rational justification that the threaded casing is capable of developing 50% of the piles bending capacity at the splice.
Proceedings of the 32nd Annual Conference on Deep Foundations, 2007, Colorado Springs, CO, USA, (DFI)
Bending Strength of Threaded Micropile Connections
Steven R. Musselman; J. H. Long; N. Carroll; S. Farr
The bending strength and flexural stiffness of a micropile at its threaded connection is less than its intact strength and may fail due to thread slippage or by fracture through the pin (reduced cross-sectional area of male threads in the threaded zone of the casing). The mode of failure depends on the reduction in cross-section necessary for machining the threads, and details of the threaded connection such as the length of threaded connection, size and shape of threads, and the thread density (threads per inch). Based on data from bending tests conducted on 9-5/8 inch diameter micropile casing, a method has been developed to predict the ultimate moment capacity and initial bending stiffness of round threaded micropile connections. Two modes of failure were observed from four-point bending tests conducted at the University of Illinois on 9-5/8 inch casing with round threads. Threaded micropile casing connections with an effective thread length of 1.35 inches typically failed by slippage at the threads (jump out), while connections using an effective thread length of 1.89 inches failed by fracture of the pin. These two failure modes were described by W.O. Clinedinst in his report to the American Petroleum Institute on tension tests of threaded pipe casing. Clinedinst developed an empirical formula to determine the tensile strength of threaded connections. A method to predict moment capacity for threaded micropile connections by modeling the micropile cross-section and applying Clinedinst's equation to determine the max tensile stress along the threaded connection while satisfying force equilibrium is proposed. The predicted moment capacity for threaded connections using this approach is within ten percent of measured for both modes of failure observed from the bending tests.
That might be worth a look.
I'm trying to quantify the capacity in bending, I'm not worried about compression.
Today the mailman delivered the paper that born2drill suggested. They tested 7"x0.5" casing in bending. It failed by thread jump. This particular casing failed at around 57% of the theoretical capacity of an unspliced casing section. But since this is just one casing size with one thread pattern it might not represent typical performance.
I would recommend to others that are attempting to predict the bending capacity of flush threaded casing.
Thanks for the suggestion Erdbau!
Thanks!
http:
The special details lessen the uncertainties of preparing joints at the worksite, in more thant using the full capacity of the overall section.
Mrturran, do you want the casing itself or the thread spec? You can get casing from several steel manufacturers. It typically comes in two grades J55 and N80. The number is the yield stress of the steel. I have no idea what the letter means.
Im looking for the threads only. Is there a standard used by pilers or do you take oil pipe threads or similar?
/Mrturran
I can´t see the point if you can only use 50 % of the pipes capacity.
We don't use external couplers or welded joints because they cost more to install and we don't need the extra capacity.
Ok, but do you need 100% in compression and/or tensile load?
By the way, I´m looking for a thread which is 100% in all three (Bend, tensile, compression). Do you know which types are used?
If you are looking for full tension you might consider all thread bar as a component of your micropile.
If you need to get the casing to 100% in tension and you want avoid a lot of welding and reinforcing of the joint, you might consider using an external coupler rather than flush threaded casing. With flush threaded casing you have male and female casing ends that thread together. With an external coupler both ends of your casing will have male ends and your couplers will have female ends. The drawback to external couplers for micropiles is that the couplers will have a larger diameter than your casing, so you will likely need to utilize an overreaming drilling system to drill a hole to accomodate the OD of your external couplers.
In the first line of my previous post the second of should be read OR
Apparently welding has detrimental effects on the high yield steel, and welding will actually end up WEAKENING the steel at the joint.
I don't know if the same holds true for J55 pipe.
SEshore, Thanks. So the reason why you don´t weld on the construcion site is becouse it´s time consuming?
In Scandinavia we use Symmetrix drilling mostly. What type do you use?
Do you know what type or name of the external couplers that are being used?
