RF filtering question
I have to filter RF signals from DC lines. I was thinking using capacitors connected to those lines and ground, shunt capacitors.
I have to filter signals from AM, 150KHz to 2GHz. I was thinking just using small capacitors which SRF is around 2GHz. But looking at some circuits I have seen they use big capacitors, the problem is that its SRF is very low, my question is the following:
Why not use just a small capacitor? as it will behave as a short circuit from very low frequencies to its SFR? unless my approach is not correct and it won´t behave as a short at very low frequencies close to DC.
Thanks.
Thanks.
RE: RF filtering question
(Is this still the same project?)
1/(2*pi*f*C)
So for instance a 15 pF cap has an impedance of 70 kohm at 150 kHz.
AVX has a nice free program, "SpiCap 3.0" for looking at decoupling caps.
http://www.avx.com/SpiApps/default.asp
Peter
Thanks for your commends, they were great, you know it is these kind of things that sometimes I feel
lost because I cannot remember the principle behind and it´s very rewarding to brush it up by someone.
Thanks.
I'd look for a box to buy and wire into your lines that already has a circuit board on it with those components.
Or, at least make a circuit card and avoid long leads on C's and L's.
If you don't draw much current, make an R C circuit. It helps alot to have a resistor in your lines, then a capacitor between your two lines.
If you have 60 hz. AC fans, you can switch to 28 Vdc to avoid noise. I had to do that way back when and it helped alot.
In general, you want a low impedance AC short circuit in shunt to ground, and a high impedance series element. If that is not enough, add another shunt AC short, then add another series high impedance element...etc, until you have achieved the desired dB of attenuation.
www.MaguffinMicrowave.com
Maguffin Microwave wireless design consulting
