CL vs yaw angle
CL vs yaw angle
CL vs yaw angle
This is specifically pertaining to ground motorsport vehicles. I'm looking for some data of the amount of down force generated by a front splitter vs the yaw angle of the car. All I have found is the downforce is significantly reduced as yaw increases (due to less stagnation of course), but this isn't enough for me.  I'm looking for some real data to work with.
i havn't had much success searching the net.
RE: CL vs yaw angle
heh, i have that book. I'll check out the references.
RE: CL vs yaw angle
There's less in there about yaw than i expected, SAE 850283 2002-01-3312
However figure 6-14 makes me think the effect is small
Hucho is another good source of references.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
