Band beam support on precast wall
What do you have to check at the support for a insitu band beam supporting on the precast wall. ie. rebate in the wall for the beam to support
Do I check bearing stress over rebate?
Do I need bars epoxy or screw into the wall or the rebate is enough?
How do I know how much rebate would be sufficient?
Do beam main longitudinal bars (top and bottom) need to have sufficient development length in the rebate?
Your suggests would really be appreciated.
