Generator Neutral Grounding Resistance Sizing
I have a generator 3000 kVA, 400 V, 50 Hz that requires a neutral grounding resistance for short circuit protection.
How can i size that resistor in detailed steps?
RE: Generator Neutral Grounding Resistance Sizing
For the start.
thread238-250961: IEEE-142-2007 Grounding of Industrial Systems
h
I would recommned to you search on the Forum too, lot of topics on the issue.
Good Luck.
Slava
Step two: Multiply the voltage by the desired maximum ground fault amps. This will give you the watts that will be dissipated by the resistor under worst case conditions.
Bill
"Why not the best?"
Jimmy Carter
Alan
