Changing rotation of Bluffton 3PH Motor.
Hi All,
I have the stangest problem, I cant change Rotation of 3PH motor.
Swapping 2 Phases together didn't help.
We used the same type of motor (it looks the same but different name Franklin or so.)and the same label with connection diagrame, it always works, but not this time,
and its not one but 8 Identical motors, all have the same problem.!
Mod. 1313017112
Bluffton
2HP wired for low voltage 230v, 3 Ph
L1 with 1,7
L2 with 2,8
L3 with 3,9
4,5,6 together
Also Tryed too play with swapping 1 and 4
means
L1 with 4,7
L2 with 2,8
L3 with 3,9
1,5,6 Together.
Result blown 2 fuse.
Please reply if you have any idea what happening or how to fix this problem, delivery of product with this motors monday, after 2 days
Bluffton free support phone don't work weekend.
Did the mess something inside? how to fix?
Anywhay will try to read more on the web.
Marwan
Mod. 1313017112
Bluffton
L1 with 1,7
L2 with 2,8
L3 with 3,9
4,5,6 together
means
L1 with 4,7
L2 with 2,8
L3 with 3,9
1,5,6 Together.
Marwan
RE: Changing rotation of Bluffton 3PH Motor.
L1 - 2,8
L2 - 1,7
L3 - 3,9
That's what is meant by swapping phases.
In my post I tryed to explain that swapping phase didn't work, L1 with L2, L1 with L3 Tryed all the combinations.
I do this on a daily basis, with different motors, never had a problem!
This is not a typical problem.
Check if this is a delta connected motor.
Wye connections have continuity between three wires in one group.
Delta connected motors have continuity between three wires in three groups.
Bill
"Why not the best?"
Jimmy Carter
I figured out that there are 8 ways to connect the polarity of the windings,
will try tomorrow, but what if not the polarity is wrong but the location of winding is wrong, like instead od 1-4 I have 3-6, and so on.
But the existing configuration, works fine, not blowing fuses, but opposite direction.
I've found on internet a way to identify all the leads using DC battery and voltmeter.
Will see if it works.
DON'T CHANGE THE CONNECTIONS OF THE NINE MOTOR LEADS.
Bill
"Why not the best?"
Jimmy Carter
Not Working.
Have a strong feeling that they messed up something in the factory.
Will keep you posted .
Thanks for everybody.
I doubt it. Follow waross's advice.
Muthu
www.edison.co.in
Are you sure that the motor is not reversing? Can you see the shaft? A centrifugal pump will pump in either direction and reach full pressure into a closed valve. The performance of the reverse driven pump falls off quickly as the valve is opened and flow starts.
Bill
"Why not the best?"
Jimmy Carter
Problem was in the power unit pump, motor was starting in proper direction, then reversed in power unit.
When motor was disconnected from power unit problem disapeared.
So motor was fine.
Thank you all.
