When leak testing gas mains, how do you determine the test duration?
When leak testing natural gas facilities, besides the minimum test durations listed in subpart J of CFR49, part 192, what are the basis of recommended test durations?
Are there any standards, codes of formulas that are used to calculate or derive the test duration?
RE: When leak testing gas mains, how do you determine the test duration?
http://www.concrete-pipe.org/pdfs1/DD_39.pdf
