Angled riser outlet
Angled riser outlet
Hello, I am modeling a concrete riser and grate in a detention pond. The 30 inch diameter grate on top of the riser will be angled to match the 3:1 slope it is embeded in. I am not sure the best way to model this angled outlet.
RE: Angled riser outlet
Peter Smart
HydroCAD Software
www.hydrocad.net
Basically, you're flattening out three sides of the grate, which will form a trapezoid.
Peter Smart
HydroCAD Software
www.hydrocad.net
For a circular grate on a slope you will probably need to use a custom weir/orifice. As before, you will be "flattening out" the perimeter so you can model it as a curved weir in 2-dimensions.
Peter Smart
HydroCAD Software
www.hydrocad.net
