Short Column Slenderness Ratio
1. I have a slenderness ration of 23.7 and my material is steel. The appropriate range for steel is 30<Le/k<120 (Structural Steel) what do you do with the equation if the Slenderness Ration is less than 30? Do you use Euler's Formula or Johnson's formula? I can't remember.
2. Schedule 40 Pipe, steel, E=29000 ksi, I=.1947, A=.6685, L=18.1, k=.5397, N=3 Euller's or Johnson's?
RE: Short Column Slenderness Ratio
1 johnson ... euler for long columns
2 N=? ... i'd use johnson
Hi mklt
I'd use the Rankine-Gordon formula for intermediate struts:-
P = stress allowable* area/(l+a(I/k)^2)
where p = safe load
      l = column length
      I= second moment area
      k= radius of gyration
       a = constant= 1/7500 for mild steel
desertfox
Desertfox - Thanks so very much for your help with this. I'm not familiar with Rankine-Gordon but I'll look into that.
rb1957 - N=3. (Ground support Equipment. What do you think? Still use Johnson?
Hi mkit
Are you sure about the slenderness ratio of steel you quoted?
It looks to me as you might not have a strut at all but a straight forward crushing mode with such a small slenderness ratio.
desertfox
desertfox,
Thanks again. You've been a great help.
mklt (Mike)
Hi mklt
your welcome
I agree with desertfox....this isn't a buckling issue...it's a crushing issue or punching issue.
