Static Analys
Static Analys
Hi all
Im a beginner and trying to modelling a flat plates in the Roark .
i have a plate 10 in x 3 in all edges all edge fixed and a uniform pressure of 100 psi over all the plate. im using the Ls pre-post for now and studying Ls Dyna Implicit Analys.
For modelling my load condition after the mesh generation, have i to load my shells with a load curve (Abscissa time , Ordinate pressure)?
Best Regards
Best Regards
RE: Static Analys
though this one is probably more appropriate, you've had some replies on the other one.
RE: Static Analys
RE: Static Analys
RE: Static Analys
