When to close out a project
At what point should you officially close a project ou?
We are an EPCM company and find on most projects that even once a plant is commissioned the client just wants "one more thing".
Even though a change order is processed and the client pays for the additional hours etc., "just to order one more spare pump", it causes havoc with closeout documentation and signoff of projects, as well as resource planning.
How do you prevent the continuation of that "never ending project"?
Does anyone have any experience with this problem?
Any advice?
Any advice?
RE: When to close out a project
At that point, you should start up a service contract at a higher rate, commensurate with the perturbation to your company's other activities. Is that so hard for your company to do?
TTFN
In most cases (and, soory, I think it's your's), the question of the end raises because the project has not been corretly started.
I explain...
Just refere to any definition of a project (Wikipedia's for instance) :
... "to meet goals and objectives ...
Think about it.
Have you clearly defined goals and objectives at the start of your project ?
If so, when goals and objectives are reached, the project has ended and it should be closed.
Any other continuation on the subject is a new Project...
Babynus
Administrator of www.toolware.fr
