spaceball-set rotate point?
I'm a long time NX user, and I've recently started using solid edge, I'm dissapointed with the performance of my spaceball (space traveller), in NX the rotation is always screen based, and so rotations are easy to control, and i can easily right click - "set rotate point" and select a centre of rotation, but in solid edge it only seems to want to rotate about the wcs, which is useless if you have a large model, is there a way to set the rotate point in solid edge?
RE: spaceball-set rotate point?
Ed Stuckey
Tony
I always assign a button to this command, and one for activate, but I use a Spaceball 4000 or SpaceExplorer.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
thread562-260283: Parts being activated when assembly loaded.
bc.
Quadro FX4600.
