3D Tool Correction (by FANUC) vs Common Correction
Hi, everyone.
I've got some questions.
Q1: Is it possible to make post output here:
MOM_force once X Y Z I J K G_cutcom D
not Dxx; xx - cutcom register as it set in Machnie Control label, but Dyy? yy is Tool Number
Example: We have tool T01 and the cutcom register is set 0 by default (Pic. below). Output must be D01. I need to know where this variable D is set as mom_cuctom_adjust_register.
Q2: I have no idea how to combine common cutter compensation (e.g. G2 G41 X0. Y0. R0. D01) with 3D correction (FANUC: e.g. G1 G41 X0. Y0. I1. J1. K1. D01)
Have anyone here had the same problem? How it could be solved?
THANK YOU!
THANK YOU!
RE: 3D Tool Correction (by FANUC) vs Common Correction
