Masonry Strength Design - LRFD
I was designing a CMU Lintel Beam as a flexural member recently and decided to compare the results using the tradional elastic analysis (ASD) approach (which I have always used) and the ultimate strength design (LRFD) approach now allowed by code which considers Whiteney's stress block.
I was startled to see that there was a huge difference between the ASD and LRFD approaches.  The stress ratios I was calculating using LRFD were significantly lower than the ASD approach (more than 40%). I expected the LRFD results would yield somewhat smaller stress ratios (perhaps 10-20% difference)since it is considering the true ultimate state, but I didn't expect the difference to be so pronounced.
Has anyone else noticed large differences in design using ASD & LRFD for masonry??
RE: Masonry Strength Design - LRFD
Can you post your calcs as an attachment?
I have noticed you get a big advantage using ultimate strength design with masonry.  I think this is because the assumptions for allowable stress design of masonry are so conservative--triangular compressive stress block, low allowable compressive stress, low allowable steel stress, etc.
DaveAtkins
I have also noted large advantages when using Ultimate Strength Design of masonry.  I noted it on this forum a few months back without much discussion on 2 different posts (kind of related to the same question).
http://www.eng-tips.com/viewthread.cfm?qid=252182&page=1
http://www.eng-tips.com/viewthread.cfm?qid=252451&page=1
I verified all of my calculations by and with the NCMA computer program... so I hope they are correct
OK, thanks guys.
I just needed a sanity check.  It seems absurd that a code would present two different methods with such differing results.
Does anyone know when strength design was introduced in the masonry code?
2002 was the first ACI 530 to introduce strength design.
