Copper in Welding Wire causing E Coat problems
During welding of a steel assembly, copper is deposited on the surface of the weld. This area will not E Coat and requires mechanical removal of the deposit. Different ways of chemically removing the copper has failed. Please suggest either a new wire composition that will eliminate the copper deposits or something to add to the chemical pre-treat that will sufficiently remove the copper before E Coat.
RE: Copper in Welding Wire causing E Coat problems
