Aluminum I-Beam
Aluminum I-Beam
A fabricator has submitted an I12x11.51 as a substitution for an I12x11.7. I can't find properties for an I12x11.51. Can anyone tell me if an I12x11.51 is a standard aluminum shape in North America?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Aluminum I-Beam
RE: Aluminum I-Beam
Mike McCann
MMC Engineering
RE: Aluminum I-Beam
RE: Aluminum I-Beam
RE: Aluminum I-Beam
RE: Aluminum I-Beam
The point is that this is a request for a change, a change order request, and, in this circumstance, it is the responsibility of the fabricator to show to you that the substitution is at least as good as your original callout. He has the burden of proof. He needs to show you the paper work. You do not need to do any investigative work here. This should be your normal "modus operande" here. (method of operation)
Cheers. Off the soapbox now.
Mike McCann
MMC Engineering
RE: Aluminum I-Beam
RE: Aluminum I-Beam
Mike McCann
MMC Engineering
