Rope in Motion environment (trebuchet)
Hellow
I want to simulate an trebuchet.
kind of a model: http://upload.wikimedia.org/wikipedia/commons/9/91/Stirling_Warwolf_Trebuchet.jpg
I want to simulate the complete model in the motion environment. But i have some difficulties with the modelling of the rope. Is there a way to model a rope in NX. If this would be possible, is it also possible to load the rope in the motion?
Greets
RE: Rope in Motion environment (trebuchet)
Thanx for the reply, but is there a way to load this rope in to the motion and apply the properties of a rope to this body. Like there are you can only pull to a rope but not push, and it bends also very easy.
I don't know if i expressed myself good enough? I hope i did.
greets
Michaël
I think there is no possibility to use deformable parts, such as ropes, belts, hoses, springs in motion analysis.
As I know Autodesk Inventor 2010 has this feature.
Depending upon how many degrees of freedom that you want you can easily create a deformable rope of some sort or another even using the simple example that I posted earlier.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
