Galvanised Steel Pipe Internal Roughness?
I perform calculations on a regular basis for water and compressed air supply to underground coal mines. The standard piping used for these services is victaulic galvanised steel pipe and as a basis for the calculations we have tried to determine a suitable internal surface roughness for this type of pipe.
I have contacted the manufacturers of the pipe and they will only give me the pipe roughness after it has been milled and before it has been galvanised.
Does anyone have any references that give the internal surface roughness of galvanised steel pipe?
Thanks very much,
James
Thanks very much,
James
RE: Galvanised Steel Pipe Internal Roughness?
Cameron Hydraulic Data (chapter 3) may help you.
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
you are absolutely right (e=0.0003 foot)
Kind regards
