Draft analysis dialog doesnt comeup
Sometimes in part design I dont find the the draft analysis dialog doesnt kickup. No matter howmany time, I click the draft analysis tool, it doesnt brigup the dialog.
Restarting SW solves this.
Does any one else face this?
BT
Windows XP Pro-64 Bit
SW 2009 Pro 64 Edition, SP3
RE: Draft analysis dialog doesnt comeup
Can be an issue with SW registry.
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MathCAD 14.0
You can try Redefining the Analysis by going to
View > Modify > Draft Analysis
View > Display Draft Analysis , now toggles whether the Analysis is active. The icon under Modify sub-menu allows you to edit the analysis as well as choose which faces you want to show or hide on screen which makes it a lot easier to find faces that don't match draft requirements.
Which Analysis are you using the one from Draft Analysis that
gives the option to keep color on faces, or the New Draft Expert option.
In 2008 SolidWorks changed the behavior of the analysis by giving it the option to give you a live update so drafted Faces are shown as they are created. While redefining you can select which face classifications to display.
Dynamic Draft Analysis
Address
3 Photos 45-47
Please see photo links or download a Zip file attached.
Michael
Michael,
I am using the View>Display>Draft analysis. But, I never observed that there were setting under View>modify.
Thanks for drawing my attn on this. Your images were helpful.
-BT
