section on different sheet
is there a way to place a section view on a different sheet than the view it was cut from in Inventor. and are there any other cut symbols available?
RE: section on different sheet
To put a section view on another sheet you need to drag and drop in the model browser. You must have the current sheet active then drag/drop to the new sheet.
