Good substitute for PC
Can anybody share what's best substitute for PC that is cheaper?
Thanks.
Cge Lang
Thanks.
Cge Lang
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Good substitute for PC
TruDesign
HDPE is a good substitute if you want to make a household bucket, but not so good for a dome for a security camera.
What properties do you need that PC has - transparency, low temp impact, chemical resistance etc.
TruDesign
Thanks once again for the input.
cge lang
Dan - Owner
http://www.Hi-TecDesigns.com
A clue to the application would be useful to give some more informative replies.
H
www.tynevalleyplastics.co.uk
cgelang
If you want useful input YOU need to draft a clear and concise question that identifies the required properties, you know, things like expected life, temperature, load, chemicals, abrasion, light transmission, UV light exposure and a few generalities, like it is used in a kitchen, or it contains electronics, it is used outdoors, it is used in contact with swimming pool or spa water etc etc etc.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
