Pressure triggered alternating value
I need a value that closes when pressure
is less than -3 Hg and releases once
it has achieved -15 Hg until it again
reaches -3 Hg. continuously.
Any suggestions on where and what I
should be looking for ? or even, if need
be - who I would need ?
Dennis
RE: Pressure triggered alternating value
Jetstream!
You ought to be more specific in that. Eventhough the unit of pressure is irrelevant to my answer but it is better to specify always. what I understood from your post is you have to cutoff a vacuum line valve when some level of vacuum is created and then to hold until it drops to a certain level. In that case you have to install a vacuum switch in the line and that indication (control signal) will be given to a control valve. If the line size is more you have to use a pneumatically actuated valve.
Truth: Even the hardest of the problems will have atleast one simple solution. Mine may not be one.
