Pressure drop across a thred-o-let
I need to estimate the dP when a gas exits a header and flows through 3/4" TOL.  This is for a very low-pressure gas sparger assembly.  How much error do you think I'll introduce if I calculate the dp across the TOL by assuming it's a sharp-edged orifice and use the usual procedure for an orifice, e.g. the procedure in Crane TP410?  Or would I be better off just assuming it's a sharp-edged pipe exit with a very short length of straight pipe?  I know this sounds like hair-splitting but the design of this sparger is critical (and expensive since it's made from 316L).
Thanks in advance for any help, comments, ideas, cat-calls, etc.
Thanks!
Pete
RE: Pressure drop across a thred-o-let
It's how I'd do it Pete.  You might want to check with the manufacturer, maybe they have some pressure drop data that you could back calculate a K factor and see how it compares to this approach.
