renaming Sketches with a Jurnal or a Macro
I'm new in this forum. I've got a little problem because I have to rename nearly 1000 sketches, and I do not know how to write a little program to help me do this work. Exactly I have to add a the same String to the name of many sketches, for example to the name of all selekted sketches. Is there anyone whow can post me a macro or a jurnal or something else to help me do this job???
best regards...
best regards...
RE: renaming Sketches with a Jurnal or a Macro
I don't believe there is a macro to rename sketches & to create one, seems like it's more trouble then it's worth.
Typically, as a best practice, the Designer should name sketches up front, such as, "SK_XSECT"
SK = Sketch
XSECT = Cross section
May be a lot of rework, but you are probably better off manually renaming. Also, having a 1000 sketches in model is a bit excessive, even if you really don't have that many.
Hope that helps.
Jason M.
Unigraphics NX & SolidWorks Designer
I don't have 1000 sketches in one part, but I got quit a lot of Parts with up to 200 sketches. I have to add the ISO-standard to the naming of the sketches. So this is really a lot of work if I do it manually. On the other hand it is a good chance to learn a little about automatization. I have another thing to do. I've got to replace a part of the naming-Sting for Example "Profile" to "Pr". To get enough free characters to ad the ISO-standard to the naming. I hope there will be a way to do so. I recorded a journal, but I do not know how to write a loop to rename all selected sketches...
' NX 6.0.2.8
' Journal created by Jochen on Wed Nov 04 08:07:41 2009 Westeuropäische Normalzeit
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Dialogfenster Anfang Skizze Eigenschaften
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Properties")
Dim sketch1 As Sketch = CType(workPart.Sketches.FindObject("Flatbar-100X10"), Sketch)
sketch1.SetName("Flatbar-100X10-ISO123456")
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
' Menü: Werkzeuge->Journal->Stop Recording
End Sub
End Module
kind regards
Jochen
The only other thing I could suggest is to use UG's Excel & attempt to write a macro within that.
Perhaps, to test it out, you may want to export or copy your data into the regular version of Excel & test in that environment.
Attempt to use as if you were setting up a part-family. I'm assuming that you now have a bunch of generic sketch names, which would make a bit harder for Excel to "find & replace" because names aren't similar.
Other then that, I'm not sure what else I would suggest by not seeing the data. Actually, there is one more - Find an intern to assist, but that's probably not an option.
Good Luck...
Jason M.
