NX6 Nastran Help Please
Hello.
I did simulation in NX6. But I couldn't see result branch in simulation tree. My f06 file is on the attechment. How I can solve this problem. Thank you.
RE: NX6 Nastran Help Please
The *.f06 file you send is very strange, please check again, look for both *.log and *.f06 files, open with Notepad.exe, copy & paste here, then we will see the error you have.
Best regards,
Blas.
.log file ;
NX Nastran V6.0 (x86 Family 6 Model 15 Stepping 13 Windows XP Service Pack 3) Control File:
Nastran BUFFSIZE=8193 $(c:/program files/ugs/nx 6.0/nxnastran/conf/nast6.rcf[2])
Nastran SYSTEM(442)=1 $(command line[6])
Nastran REAL=530841600 $(program default)
JID='D:\emesnastran\model1_sim1-solution_1.dat'
OUT='./model1_sim1-solution_1'
MEM=104857600
MACH='x86 Family 6 Model 15 Stepping 13'
OPER='Windows XP'
OSV='Service Pack 3'
MODEL='Intel(R) Core(TM)2 Duo CPU T5450 @ 1.66GHz (kadir)'
NPROC='2'
CONFIG=6
NPROC=2
symbol=DELDIR='c:/program files/ugs/nx 6.0/nxnastran/nxn6/nast/del' $(program default)
symbol=DEMODIR='c:/program files/ugs/nx 6.0/nxnastran/nxn6/nast/demo' $(program default)
symbol=SSSALTERDIR='c:/program files/ugs/nx 6.0/nxnastran/nxn6/nast/misc/sssalter' $(program default)
symbol=TPLDIR='c:/program files/ugs/nx 6.0/nxnastran/nxn6/nast/tpl' $(program default)
SDIR='d:/emesnastran/model1_sim1-solution_1.T1432_13'
DBS='d:/emesnastran/model1_sim1-solution_1.T1432_13'
SCR=yes
NEWDEL='c:/program files/ugs/nx 6.0/nxnastran/nxn6/i386/SSS'
DEL='NXNDEF'
AUTH='28000@kadir'
AUTHQUE=0
MSGCAT='c:/program files/ugs/nx 6.0/nxnastran/nxn6/i386/analysis.msg'
MSGDEST='f06'
NEWS='c:/program files/ugs/nx 6.0/nxnastran/nxn6/nast/news.txt'
NXN_ISHELLPATH=C:\Program Files\UGS\NX 6.0\nxnastran\bin
NXN_JIDPATH=
PATH=c:/program files/ugs/nx 6.0/nxnastran/nxn6/i386;C:\Program Files\UGS\NX 6.0\ugii;C:\Program Files\Nokia\PC Connectivity Solution\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;C:\Program Files\Hummingbird\Connectivity\11.00\Accessories\;;C:\Program Files\Microsoft SQL Server\80\Tools\Binn;C:\Program Files\Common Files\Autodesk Shared;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Common Files\Roxio Shared\DLLShared\
Current Dir: D:\emesnastran
Executable: c:/program files/ugs/nx 6.0/nxnastran/nxn6/i386/analysis.exe
NXN_MSG: stderr
FPE: yes
Current resource limits:
Physical memory: 2037 MB
Physical memory available: 1210 MB
Paging file size: 3933 MB
Paging file size available: 3217 MB
Virtual memory: 2047 MB
Virtual memory available: 2032 MB
NX Nastran started Tue Nov 3 22:07:13 GST 2009
22:07:18 Beginning Analysis
All SSE XMM operations have been enabled.
All MMX operations have been enabled.
22:07:18 NX NASTRAN Authorization Information - System Attributes
22:07:18 --------------------------------------------------------
22:07:18 Model: Intel(R) Core(TM)2 Duo CPU T5450
22:07:18 Machine: x86 Family 6 Model 15 Stepping 1
22:07:18 OS: Windows XP
22:07:18 Version: Service Pack 3
22:07:18 License File(s): 28000@kadir
UGFLEXlm Log: License server "28000@kadir" has been connected.
22:07:18 MAIN: "Access violation" (C0000005) exception encountered.
22:07:18 MAIN: For reference, A(MAINAL) = 4012B0, A(/SYSTEM/) = 1DC2460
22:07:18 MAIN: /XNSTRN/ has not been defined.
22:07:18 MAIN: Exception occurred at address 10007A58.
22:07:18 MAIN: Program attempted to access data at location 4E5F584E.
22:07:18 MAIN: Context Flags 0001003F
22:07:18 MAIN: EAX 4E5F584E EBX 01DF04E4 ECX BB9F6AC7 EDX C1B1EBFA ESI 0012F394 EDI 0012E988
22:07:18 MAIN: EBP 00000000 ESP 0012E924 EIP 10007A58 EFLAGS 00010297
22:07:18 MAIN: The 32 bytes around exception location 10007A58 are --
22:07:18 MAIN: 10007A48 FF FF 8B 44 24 08 BA 48 44 11 10 83 C4 04 2B D0
22:07:18 MAIN: 10007A58 8A 08 88 0C 02 83 C0 01 84 C9 75 F4 EB 0D 68 3C
22:07:18 MAIN: FPU Control Word 0273 StatusWord 0120 TagWord FFFF
22:07:18 MAIN: FPU EIP 0043D9A0 OpCode 011D DataOffset 01DC25F8
22:07:18 MAIN: Data at 01DC25F8 is 00008025 00000000
22:07:18 MAIN: FPU Reg 0 (Tag 3) 8398001182B000118154 EMPTY
22:07:18 MAIN: FPU Reg 1 (Tag 3) 0222FFFFFFFF7C910228 EMPTY
22:07:18 MAIN: FPU Reg 2 (Tag 3) 86CC000000007C9101DB EMPTY
22:07:18 MAIN: FPU Reg 3 (Tag 3) 9B7800129B8400000008 EMPTY
22:07:18 MAIN: FPU Reg 4 (Tag 3) BB44004153F7004ABB44 EMPTY
22:07:18 MAIN: FPU Reg 5 (Tag 3) 00000000000000000000 EMPTY
22:07:18 MAIN: FPU Reg 6 (Tag 3) 3FCA8000000000000000 EMPTY
22:07:18 MAIN: FPU Reg 7 (Tag 3) 3FCB8000000000000000 EMPTY
22:07:18 MAIN: The 256 words on the stack, starting at 0012E924, are --
22:07:18 MAIN: 0012E924 004163D1 4E5F584E 52545341 00004E41 003E2AF0 302E3432 30303030 7C900030 *.cA.NX_NASTRAN...*>.24.000000..|*
22:07:18 MAIN: 0012E944 7C9101E0 FFFFFFFF 7C9101DB 7C9114D6 7C911514 7C97E120 7C9114EA 001440A4 *...|.......|...|...| ..|...|.@..*
22:07:18 MAIN: 0012E964 00144090 00000000 7FFDF000 7FFDE000 001477C0 0012E8CC 00000000 0012FEB8 *.@...............w..............*
22:07:18 MAIN: 0012E984 7C90E920 30303832 616B4030 00726964 7C97E140 00144090 00000000 00000000 * ..|28000@kadir.@..|.@..........*
22:07:18 MAIN: 0012E9A4 7C90DF8A 7C810E96 00000764 00000000 00000000 00000000 0012E9E4 0012EA44 *...|...|d...................D...*
22:07:18 MAIN: 0012E9C4 00000024 00000000 7C810EB6 00000024 00000048 02C24900 7C810EB6 0000001B *$..........|$...H....I.....|....*
22:07:18 MAIN: 0012E9E4 00000000 00000024 0012E9D0 00000036 0012EE78 7C90DF8A 7C810E96 00000764 *....$.......6...x......|...|d...*
22:07:18 MAIN: 0012EA04 00000000 00000000 00000000 0012EA38 0012EA98 00000002 00000000 7C810EB6 *............8..................|*
22:07:18 MAIN: 0012EA24 00000002 00000048 02C24900 7C810EB6 00000029 00000000 00000002 0012EA24 *....H....I.....|)...........$...*
22:07:18 MAIN: 0012EA44 3A323220 0012EECC 7C839AD8 7C810EC0 FFFFFFFF 7C810EB6 01BBD176 00000764 * 22:.......|...|.......|v...d...*
22:07:18 MAIN: 0012EA64 0012EA98 00000002 0012EA80 00000000 00000048 00000002 01BBD24E 00000002 *................H.......N.......*
22:07:18 MAIN: 0012EA84 00000001 00000002 032B4D59 00000002 00000000 00000A0D 032B4D80 00000029 *........YM+..............M+.)...*
22:07:18 MAIN: 0012EAA4 00000000 3A323220 313A3730 4C202038 6E656369 46206573 28656C69 203A2973 *.... 22:07:18 License File(s): *
22:07:18 MAIN: 0012EAC4 30303832 616B4030 0D726964 7562690A 0D736574 6172650A 6E6F6974 61682073 *28000@kadir..ibutes..erations ha*
22:07:18 MAIN: 0012EAE4 62206576 206E6565 62616E65 2E64656C 0A0D0A0D 00330031 0066002E 0012EB34 *ve been enabled.....1.3...f.4...*
22:07:18 MAIN: 0012EB04 00140000 7C910222 00000045 00141378 00140000 001420A0 0012EB0C 0012ED4C *...."..|E...x........ ......L...*
22:07:18 MAIN: 0012EB24 0012ED50 7C90E920 7C910228 FFFFFFFF 7C910222 7C91019B 7C9101DB 00000000 *P... ..|(..|...."..|...|...|....*
22:07:18 MAIN: 0012EB44 0012F084 0012F05C 7C90E920 7C910228 FFFFFFFF 7C910222 7C91019B 7C9101DB *....\... ..|(..|...."..|...|...|*
22:07:18 MAIN: 0012EB64 00000000 0012F0A8 0012F080 0012ECB0 00000000 01000007 0012EC38 44360032 *........................8...2.6D*
22:07:18 MAIN: 0012EB84 00000000 00000000 7FFDEC78 7C910435 7C91043E 00007DDE 0012EBD0 00140000 *........x...5..|>..|.}..........*
22:07:18 MAIN: 0012EBA4 7C910222 00000004 00140748 00140000 00145CE0 0012EBA8 001420A8 0012EBF4 *"..|....H........\....... ......*
22:07:18 MAIN: 0012EBC4 0012EBF8 0012EBFC 00140000 7C910222 00000045 00141378 00140000 001420A0 *............"..|E...x........ ..*
22:07:18 MAIN: 0012EBE4 0012EBD4 0012EE14 0012EE18 7C90E920 0012EC28 00140000 7C910222 00000045 *............ ..|(......."..|E...*
22:07:18 MAIN: 0012EC04 00141378 00140000 001420A0 0012EC00 032B4D50 0012EE44 7C90E920 00000000 *x........ ......PM+.D... ..|....*
22:07:18 MAIN: 0012EC24 01BC127F 00000000 00000040 01BC1A12 01BC14E8 0012F030 0012EEFC 01BC1A61 *........@...........0.......a...*
22:07:18 MAIN: 0012EC44 01BC14E8 0012F040 0012EF0C 00000000 00000000 00000000 0012EF1C 00000000 *....@...........................*
22:07:18 MAIN: 0012EC64 00000000 00000000 00000002 00000000 00000000 0000000B 00000002 0012EE8A *................................*
22:07:18 MAIN: 0012EC84 00000000 01BC127F 00000000 00000040 01BC1A12 01BC14E8 0012F094 0012EF60 *............@...............`...*
22:07:18 MAIN: 0012ECA4 01BC1A61 00000040 00000002 0012EEBA 00000000 00000000 00000000 0012EECA *a...@...........................*
22:07:18 MAIN: 0012ECC4 00000000 00000000 00000000 00000002 00000000 00000040 0000000B 00000002 *....................@...........*
22:07:18 MAIN: 0012ECE4 0012EEEE FFFFFFFF 00000040 7FFDEC00 00000000 02080064 00000045 440E000C *........@...........d...E......D*
22:07:18 MAIN: 0012ED04 00000064 00000000 00000003 0012EE3C 00000000 01E86D86 0012EDD8 44E86D86 *d...........<........m.......m.D*
22:07:18 MAIN: The stack data starting at 00000000 is not accessible.
22:07:18 NSEXIT: EXIT(20)
22:07:18 Analysis complete -20
FORTRAN STOP 20
Real: 4.921 seconds ( 0:00:04.921)
User: 0.093 seconds ( 0:00:00.093)
Sys: 0.000 seconds ( 0:00:00.000)
NX Nastran finished Tue Nov 3 22:07:18 GST 2009
1 * * * END OF JOB * * *
*** USER WARNING MESSAGE 1152 (XCLNUP)
SOME DBSETS IN THIS DATA BASE WERE NOT INITIALIZED COMPLETELY.
USER INFORMATION: THE DATA BASE CREATED IN THIS RUN IS TOO IMMATURE TO BE RESTARTED.
USER ACTION: DELETE THIS DATA BASE BEFORE STARTING YOUR NEXT RUN.
The NX/Nastran solver has crashed. You should report and send you model to Siemens.
www.Roshaz.com
In fact, better send the model to GTAC support people, without the NX model in hands is difficul to assess what is wrong based in *.log & *.f06 files, sorry for not being possible to help you.
Best regards,
Blas.
Are you running NX with Femap or NX standalone?
A have a vague memory that this kind of error could happen when I used MSC.Nastran for Windows and made changes in the bulk data section. It is possible that NX with Femap has the same kind of "lock".
Thomas
When I said NX standalone I meant NX Nastran standalone. Are you using some kind of bundled bersion within the NX environment?
Also, are you doing any changes to the dat-file or just trying to run it. My idea came from the last part of the fo6 file "THE DATABASE IS TO IMMATURE". I really don't know NX but I recognized the "IMMATURE" statement. The real problem might be something else entirely.
Thomas
