Change case for a Linked annotation
I am working on a drawing. I have all the information in the title block and the notes derived directly from the model. I have used linked annotation for this.
Notes needs to appear in upper case only. One of the notes is related to the material of the part. I have linked material property from the part.
Issue : All the notes appear in upper case but for the material. Is there a way to change case for the derived part information.
I have tried the format painter, it doesnt work.
BT
RE: Change case for a Linked annotation
I don't think it will work until we change the font style for material in the database but still not sure if it will work in this way or if we can do this. Only option I can think of is that you can key in the material name manually.
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MathCAD 14.0
Deepak,
Thanks for the tip.
I would try to avoid Keying in manually. However, I will dig into & see how to modify the fonts for the database.
