BASLER DCIM Module
BASLER DCIM Module
Hi all,
I'm looking for a source for a Basler DCIM, part number 92745 00101. This is a communinations module for older DECS 15 digital regulators. I have a customer with multiple units at multiple sites with these regulators, they used to have a DCIM at each site, but all have disappeared. Talked to Basler today and no luck, any ideas would be appreciated.
Thanks, Mike L.
Thanks, Mike L.
RE: BASLER DCIM Module
I may have a solution for you, if you need Basler DCIM PN 9 2745 00 101 ( with bestcoms Decs 15 – DOS ) to communicate with DECS version 1.6.0.
Best Regards
I'm still looking, was able to get a loaner, apparently the last one in exisitance at Basler, but I have to return it ASAP. If you know where I can buy one or if there is an aftermarket replacement available I'd sure appreciate it, I have about units with this older regulator I need to support.
Thnks, Mike L.
You can contact Basler Electric International.
It is the international division of Basler which is based in France.
They still have DCIM modules in stock.
http://www.basler.com/html/international.htm
Normally you will be asked to contact Basler in the US (if you are from the US) but if you explain your case it may work.
Best Regards,
Mike L.
