LRUT for Electric Traced oil & Gas flowlines
I would appreciate if some one let me know the availability of LRUT (Long Range Ultrasonic Test) inspection technique for 4" to 42" flow lines and headers in Canadian Oil Sands.
RE: LRUT for Electric Traced oil & Gas flowlines
LRUT is available for most of pipelines with the following characteristics:
Wave: Ultrasonic
Operating frequency: 5kHz to 250 kHz
Pipe temperature: any temperature less than 300 Celsius degree
Inspection range: 20 ft to 500 ft along one direction depending on the pipe condition
Sensitivity: usually 2 percent pipe cross-sectional area. It is highly increased by using sectional probe that covers section of pipe.
The LRUT technique has significantly upgraded in sensitivity by using sectional probe in inspecting especially big diameter pipe.
Please use the LRUT technique and save time and money.
Sang Kim
http://www.gwanalysis.com/
