ASME B16.34 section 6.4 valve joints question
We have been engaged in a raging debate about interpretation on the calculation of Ag defined in ASME B16.34 sections 6.4.1 and 6.4.2 as it pertains to ball valves. Specifically, we are discussing section 6.4.2 and the bolts between the adapters and body. As the spec reads "Ag = area bounded by the effective outside periphery of a gasket or O-ring or other seal effective periphery".
The question is simple: Does this definition suggest that we take the full diameter (including the flow are) to the sealing face or do we use this diameter less the flow area?
The verbiage "area bounded" seems very clear that it's the full area, but thinking practically, only the area of diametral difference between the OD of the sealing face and the ID of the bore is seeing pressure loads going into axially stretching the bolts.
If we use the full area, some valve designs need to have a ridiculous number and/or size of bolts, whereas using the later approach, the numbers seem more "realistic".
Any thoughts / comments / best practices would be much appreciated.
Jeff
Jeff
RE: ASME B16.34 section 6.4 valve joints question
What are others doing in practice?
Thanks.
Jeff
Using the seat seal ID or OD would certainly make for a smaller required bolt area. However, as we understand the spec, that's not the OD that the spec is referring to. I'd love to be proven wrong on this one!
That's a good point. I am looking into this option right now as well, but I'm hoping for more of a quick answer of what others are doing when designing ball valves.
Thanks for the input!
How are others interpreting this?
Jeff
I have no reference to the specifications that your referring to however I agree with you the bolts are tightened onto the gasket or 'o' ring and the area that reacts the bolt load can only be the od of the sealing face less the id of the bore.
To get the load in the bolts it would be conservative to take the system pressure and multiply the od of the seal face to get the total force and I see nothing wrong with that but when you seal the joint with the gasket to get the compressive stress in the gasket it can't be anything else but the cross sectional area of the gasket.
desertfox
thanks for the reply.
We did some investigation here and noticed that the ASME B16.5 spec for # of bolts and their sizes very nearly meet or just exceed the calculation in B16.34, if using the full effective seal diameter area and not subtracting out the flow diameter area.
Unfortunately, this supports the argument in the way that I did not want it to go. I was really hoping to find an easy and reliable interpretation that would support being able to subtract out the flow diameter area.
Jeff
Perhaps I misinterpreted your first post, I see nothing wrong with using the outer diameter of the seal face for calculating the bolt loads ie (area * pressure) as stated previously this would be conservative in my opinion.
Howver I thought you meant were taking the seal area to be the same and trying to get bolt loads to compress the seal over the full area which didn't make any sense to me.
In the past I have used both the outside area of a vessel and sometimes the mid line perimeter of the seal or gasket face to get the joint bolt loads.
regards
desertfox
no problem. I tried to be clear, but sometimes these sort of things are difficult to explain in text. :)
the spec is pretty clear that it's the area bounded by the gasket. I've attached a picture of what I'm looking for. Perhaps that will help.
Thanks for the thoughts and help so far!
Jeff
Its a radial seal then it would be the od of the seal you require for the bolt calculation, I thought it might of been like a gasket sitting on the face of two flanges.
desertfox
My picture was not completely correct. The seal OD should be the OD of the adapter at the O-Ring groove almost directly below the bolts in question. However, I don't believe this changes your answer. It certainly does not change my understanding or interpretation.
I was hoping to reach the conclusion that we could subtract the area of the flow diameter, but all our reserach and the input from this forum seems to suggest that we can not.
I am still going to pursue putting in a request for interpretation with ASME. Hopefully that will definitvely answer this once and for all.
Thanks for the help everyone!
Any other thoughts would be most appreciated.
Jeff
