Pipe Sections replacement for 8" line
We have to replace about 8 section on a 8" NPS pipe with Wt 0.188". The available pipe joints are of slightly higher schedule #20 thk 0.25" and #40 thk 0.322.
Could some one please clarify if these sections may cause problem for intelligent pigging?
As intelligent pig is normally 95% of pipe bore, I think these replaced sections will not pose any problem as ID difference between pipe sections with different schedules will be 3.2% max.
Any comments will be appreciated.
RE: Pipe Sections replacement for 8" line
That said, a general rule of thumb that I've seen used is that the maximum variation in internal diameter of an 8" pipeline be limited to 6/16" (0.375").
Variations in wall thickness should be done with transitions that have a 1:5 slope in order to prevent hard impacts on tool sensors.
The problem is ours being a bid oriented award of job contracts, it can never be determined which of the ILI companiey may get the job.
Anyway is there any thumb rule to arrive at 6/16" limit for 8" pipe or for other different pipe sizes.
4" = 3/16"
6" = 4/16"
8 to 12" = 6/16"
14 to 20" = 9/16"
20 to 36" = 10/16"
36" and larger = 13/16"
Again these are rules of thumb but given they've been around for awhile and tools are becoming more flexible, they are probably conservative.
I know many vendors have specialized dual diameter tools that can take significant diameter restrictions but for a variety of reasons (including maintenance pigging), it is best to minimize your ID variation as much as possible.
Taking this into account, many Operators "negotiate" rather strictly bidding their ILI tool runs. They go out for prices and make it clear that they will award based on best value rather than lowest price.
There was a paper published a few years ago (by an Operator) that analysed the total cost of an ILI tool run in comparision to the quality and accuracy of the tool used. In particular, they considered the number of digs they could eliminate by having a more accurate tool (with smaller error bands on the reported anomaly size) and the money they would save on digs vs. the extra money they had to pay for the tool run itself. Overall, they reported it could be significantly cheaper to pay for a more expensive ILI system.
Anyway thanks for comments
