Noise measurement of equipment.
I am working on the design of office computer equipment with a view to reduce noise level.
I think noise levels would be 30-60 dBA. Not sure of frequency levels.
I would like some advice on choosing a noise meter and what features to go for.
There are many meters on the market ranging in price from 50 to over 1000
Thanks in advance
Thanks in advance
RE: Noise measurement of equipment.
You will also need a suitable environment in which to measure the noise - this probably means renting an anechoic chamber.
M
Dr Michael F Platten
- Steve
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
It has been decided to look at noise levels of components individually. This means measuring even smaller noise levels.
I do not need to work to a specific standard. I just need to judge if I am reducing acoustic noise level and comparing performance with other similar products.
So far testing is very subjective. I record sound levels under similar conditions. Do spectrum analysis with Acoustic software and judge if there is any improvement.
Could anyone recommend a more quantitive test method?
Thanks again
On the other hand just working out what frequencies dominate and then searching for the source with the mic is a perfectly sensible approach that avoids all the maths and many puzzles.
Photos, plots etc would probbaly yield more helpful advice.
Cheers
Greg Locock
Also, a comment on the OP. Noise signature levels are typically specified as XX dB at YY distance (e.g. 60 dB at 10 meters.)
Reidh
