Setting up a hot wire anemometer
I am measuring airflow in a circular duct with a hot wire anemometer. Is there a rule of thumb for how long the upstream and downstream sections need to be?
RE: Setting up a hot wire anemometer
At least 6 and preferably 10 diamaters upstream to any "things".  It's good to have the same downstream too.
This is generally impossible in most real systems.
Is that going to be a stationary anemometer or are you going to traverse the duct with it?
rmw
It will be stationary.
if you have a questionable straight section, use the 80/20 rule.
Put the probe 80% down the length.
Example there is an 8 foot run between two elbows, install it 8x0.8 = 6.4 feet down stream of first elbow.
Try traversing it there first, see what you get. Use that to scale up/down what the stationary reading gives you.
The way we build has a far greater impact on our comfort, energy consumption and IAQ, than any HVAC system we install
