AMMONIA STORAGE HEAT ABSORBTION
Hello all,
What heat transfer coefficient should be used for calculation of heat absorbed through the surface of an ammonia storage tank at about -35 C (the ambient temp is around 30 C).
Best regards,
roker
Best regards,
roker
RE: AMMONIA STORAGE HEAT ABSORBTION
http:/
the link in the forum is
http://www.thermal-wizard.com/tmwiz/default.htm
All you need is the specific heat and thermal conductivity at your conditions and you should be OK.
-Mike
