RVP of crude oil
RVP of crude oil
Dear ALL,
I'm optimizing our process and try to reduce stablize crude oil temperature from 56oC to 52oC, can you tell me what does RVP effect? and what's RVP and how to calculate it?
thank yuo very much
binbin
thank yuo very much
binbin
RE: RVP of crude oil
For more information about Reid Vapor Pressure, read this article the Citizendium online encyclopedia:
Reid vapor pressure
Milton Beychok
(Visit me at www.air-dispersion.com)
If you raised the temperature in the bottom of the stabilizer column 4 degrees, the RVP will drop, if you lower the bottom temp 4 degrees, the RVP will increase
Can some one help me to do slug flow analysis in CaesarII program
