Soft for Fault Analysys, Relay Coordination,
3
Dear All.
I would like change area of my job and would like start with fault calculation and relay coordination for small apllication only. Up to 150nodes and 10-20 bars, radial system only.
I do it always handly and with some macros in Exeel.
I know about grands like to SKM, ETAP, NEPLAN, EDSA. CAPE etc.., but are not for me ( I can't invest so lot of money and lot of time for learn), Im locking for something more simple, and of course cheaper and of course type-tested ( if possible saied). I know about good free products, but can't use it.
What you can recommend?
Thanks in advance.
Best Regards.
Slava
RE: Soft for Fault Analysys, Relay Coordination,
Neplan once distributed a 30-bus version for free. I do not know, what is the situation now, but it may be worth checking. By the way, why can't you use the free products?
Dear ijl.
Im want use your great soft, is good for me and more than enough.
But, I have used it for commercial propose and not sure if it possible. Customer can request from me certificate of this soft.
Best Regards.
Slava
Slavag,
I know there is a free software Inter Pss (interpss.com) with S/C calculations.
may worth you have a look at it.
of course, main issue is customer being not reluctant to trust such free softwre ( lack of certificate)
nevertheless, i saw few testimonies on the site regarding users experiences.
regards.
Oops..., the Neplan was 30-node demo version.
Slavag,
Siemens PTD used to make available its own software (Sincal and so on) thought internet with a pay per hour policy.
You should found out if it is still possible.
Regards.
Slava,
Most of the big names have a lite version with limited bus capability. They are much less expensive.
JIM
Thanks a lot for your attention.
I have been check all possibilities.
ZapSib, thanks you for information about Siemens soft,few intresting options and possible a good local support.
BTW, are someone work with soft of PSI.
Best Regards.
slava
