anchor bolt embedment length with welded plate
i left all my books at my house.. anyhow, am searching the internet for a guide to design embedment length with welded plate at the bottom.. also designing the plate thickness and width
thanks,
thanks,
RE: anchor bolt embedment length with welded plate
The plan dimensions are sized to ensure concrete pullout doesn't happen. Unless you have an unusual condition, I would just use a nut tack welded to the rod. Unless you have a sea of concrete on all sides and a large embedment, pullout is not likely to control your design.
If you just want to know. Size the plate to ensure the factored bearing stress is less than 8f'c*phi, where phi is .65 (I think).
In that case your embedment depth will be controlled by the depth needed for the development of a standard hook in tension (ldh), where ldh is calculated from the base of the anchor rod.
ACI 318-08 Appendix D has a good picture showing this.
i'm home and have my books..
